Hello:
any buddy let me know where i find the Plastic advisor option in Creo 2.0?
File > Save As > Plastic Advisor
Hello:
I was check plastic advisor in not in save as option only save a copy, mirro and save a back nothing more what can i do?
Check Plastic Advisor in the installation process. Default is unchecked.
thanks you!
now need to instuall again or any other option to add?
I am not sure if it is possible in current installation. Try reconfigure.exe in install Creo Parametric/Bin directory.
thanx
