Creo 2.0: Restyle filling open gap
Jacek_Mydlikows
6-Contributor
I work on STL data with Restyle environment
I want to close an open gap(below). Fill hole tool does not work because it requires closed loop(so far I imagine this could be a cause)
I thought I can add faces but, created ones do not maintain the shape/curvature of adjacent faces
How do you solve such issues?
Why would you ever try and work on an STL file? Is that all you have? I got nuthin'.....
This is because this is faceted geometry. It has no curvature information to follow.
This looks like a 3D scan. There are a few scan tools but I suspect they belong to an optional package.
The best you can do is approximate a patch but it won't merge.
thank you guys
as I wrote before I have REX license for testing. At first glance, whole environment does not look friendly, and it works really slow.
