Does anyone know how to save text styles that have been created? They were carried over from my Wildfire 3 template but it keeps changing the font from blueprint to win_font. Any help would be appreciated.
I put in a ticket on this and will be fixed in M060.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS114749
You might need to set the default font to the blueprint font.
Add the option in the detail.dtl file: default_font bluprnt.ttf
I don't use TTF as default, but this should work. I add a custom detail.dtl file in my config.pro:
drawing_setup_file C:\<full path>\<filename>.dtl
...that way it doesn't get deleted with software updates
Thanks for reporting this, Andrew!
Thank you both for the information.
No problem. Was driving me crazy for like 2 weeks. Finally got it reported and got a "quick" turn around on the fix.
