Hi All
I use Creo 2
I would like to know, if there's a way to disable the initial dimensions that apear automatically right after you create your sketch. Cause they are very annoying and I would like to create my own and only see those ones, since in some zoom scales they get mixed and make it impossible to see the sketch
No, you can not disable the creation of weak dimensions. I just ignore them. As I add strong dimensions, weak dimensions disappear. I know I have a fully constrained sketch when there are no more weak dimensions or constraints
