ESD Symbol (Triangle with struck trough hand)
J.Wagner
9-Granite
does anyone know where I can get an ESD symbol (Triangle with struck trough hand) from.
Or do I have to create it myself.
Here's a picture of it
Best Regards
Jens Wagner
my request was too urgent 🙂
I created one by myself.
For those who need it, it's attached.
Thanks anyway.
Sorry, but yes, these have to be created unless you are lucky enough to find a vector file that can be imported.
The idea that you can underlay an image is helpful. And you can also consider using the image as a texture (Decal).
The only tip I can give you in creating symbols is to avoid filled polygons (solid hatch). I have had a lot of trouble with graphic errors. Trimmed offset lines representing close hatching is the best way to create a solid field. Have a close look at some of the supplied symbols and you will see this.
Hello Antonius,
thanks for that hint. I will keep it in mind.
Best Regards
Jens Wagner
