Eliminate Pro-Program Prompts
dgschaefer
21-Topaz II
WF4, unfortunately
I have two gear based parts that have pro-program input sections in them to define the gear teeth.  These are molded parts and now tooled, but every time I regen the assy they prompt me for new values.  I'd like to remove the prompts but I'm not familiar with pro-program.  What do I need to do to eliminate them?
LinkedIn
TomU
(To:dgschaefer)
Just delete anything between INPUT and END INPUT near the top of the Pro/PROGRAM statement (Tools -> Program -> Edit Design). This will stop it from prompting you for new parameter values. See the help documentation for more info (Functional Areas -> Fundamentals -> Program -> Editing a Design -> Input Parameters and Prompts).
Tom U.
Tools/Progam/Edit Program (to change) or Show Program (to view only)
I believe they are statement groups bounded by INPUT and END INPUT that gather data. Just delete them or comment them out using "/*"
Also, I believe you can define a parameter and use it in an IF/END IF block in the input section to allow controlling for prompting. For example:
INPUT
IF RUN_PROGRAM == TRUE
parameters for input
ENDIF
END INPUT
Yes, the "switch" described by David is probably the very best choice for a few reasons.
