Fastners
ptc-4510561
Fastners
Can anyone please tell me that how to create Stud with the parameter M3x0.5 length 8mm ?
It would be better if some one have created & share .
This is image is an illustartive image.
You need to have dimensions and normally its related with dia of the stud.
So if you know what are all the dimensions to be applied you can calculate relating to D.
Dhinesh
create the stud with major diameter and by extrude or revolve feature, then use cosmetic theread for minor dia. else u can manually do the helical sweep thread.
