File converion from .pkg into .pk2
Opyone
Hi guys,
I had an old project which is not opening with my current version of creo.
Can someone convert the file in .pk2 for me please? The file is .pkg
Can you give me your email so I can transfer you the file?
Best
FriedhelmK
17-Peridot
(To:Opyone)
Hi Stephane
That`s not normal
If you have the full version to save .pkg you can open older versions of the program "ptc Direct Modeling".
But if you have only ""Direct Modeling Express 6.0" or earlier there is only one way.
Unfortunately Pkg and Pk2 are incompatible.
The only way is to save Pkg as .step  and load this in Express X.
I'll can do that for you. Have a look in your post.
Again unfortunately, if you have made some drawings in Annotation you will lose them.
All connections between model and drawing are no more present after this transfer.
Best regards
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
FriedhelmK
17-Peridot
(To:Opyone)
Hi Stephane
That`s not normal
Best regards
can you please save my .pkg as step, How can I transfer the file?
Best
FriedhelmK
17-Peridot
(To:Opyone)
I sended yesterday a private mail to you with my emailadress.
Not seen?
Opyone
(To:Opyone)
No I did not see anythnig, plase send me an email at
Best
