I may have asked something similar before, possibly associated with large deformation analysis.
Friction requires large deformation analysis.
Am I right that we can't have a ground spring if we do the above?
I guess calculation of friction (contact) is nonlinear.
Nonlinear analysis is not supported with non-simple spring - this has been confirmed for Creo Parametric 2.0
(by mistake the article CS94508 was not visible - I changed this now)
Thank you Gunter,
A work around used in these events is to have a simple point to point spring. Keep the points close together. Constrain one end of the spring with a normal displacement constraint effectively making it a ground spring.
If stiffness is required in more than one direction, create mutually perpendicular springs to a common point, each spring's second point has its own displacement constraint (ground).
