Hii,
I am using creo 3.0 and i have created a std. template, but while printing the content of the title block is not displaying properly means it getting distracted. please suggest me what should I do .
I have attached image for your reference.
Thanking You,
the picture you attached does not make any sense.
MH
Sanjay,
You may share a sample drawing which we can look for test this.
