Hi I want to create teeth on the curved surfaces. I tried projecting the teeth sketch on the curve it's showing error.
Here by I am attaching my model file for reference. Please help me out to resolve this.
please upload your Creo part, not PDF ! And attach it to this discussion !
MH
Make the tooth-ridge solid and extrude/cut a single V. Then pattern the V cut.
Is this a functional gear or simply a tooth pattern? What is the purpose of the model? The what is the purpose of the part? etc...
Look for the wrap option (not warp). Create a cylinder surface and then wrap a datum curve that is the shape of the teeth onto it. Then create a variable section sweep driven by the edge of the cylinder and referencing the wrapped curve. Not going to guarantee it works; but that's what I would try.
...a few VSS options:
Hi Antonius,
Could you please attach Creo file for the same.
