I need to get the path in the save as dialog box . I was able to get the model name. But cant able to get the file save as path.
You should be able to click in the address bar to the right of Documents, and it will change to a path statement. You can then highlight, copy and paste that as a link. See Pics...
In Reply to Srinivasan V:
