How to traverse through the Vertices of an edge.
kapeelpatel
From edge, can we get its Vertices. there is something called PRO_EDGE_START and PRO_EDGE_END. But how can we get the object of the verices.
You have to use a parametric equation from t=0 to t=1 by using either
ProCurveXyzdataEval or ProEdgeXyzdataEval.
Patrick Williams
Application Engineer
Steelcase Inc.
