Insert Advanced Pipe in Creo ?????
ptc-944906
In Pro/E wildfire there was Insert : Advanced : Pipe.
Does anyone know where this is in CREO?
Brian
Constantin
(To:ptc-944906)
Are you talking about creo1 or creo2? In 2 you can find it via the search (top right corner) which also tells you that it is not part of the ribbon interface...
Constantin
(To:ptc-944906)
I am working in CREO 1 ! I tried typing it in the search box, but I didn't come up with anything.
Constantin
(To:ptc-944906)
Hm, sorry, I do not have creo1 anymore to check it...
So what did you type in your search?
It worked I just didn't understand the functionality of the search box and I was typing in insert instead of pipe.
I still don't know how people figure out all these changes on their own. I feel like I am missing some life changing resource that will solve all my problems.
Brian
With a part file open, I went to the CUSTOMIZE QUICK ACCESS TOOLBAR and then looked under ALL COMMANDS, it is in there under PIPE. I added it to my quick access toolbar and I am sure you could add it to other toolbars as well.
Hope this helps
