I just spent my afternoon working on Pre-Beta CREO 4. I found it interesting to see where things may be going.
interesting in the positive sense?
I just try it one week ago. It seems the performance is improved more quick than Creo 3.0
Can i know where did you found CREO 4.
I am also interested to see CREO 4
Jignesh
I forgot I signed up for that. I think it expires tomorrow. I won't have time to go through it...
I would concur with gzhou-2
1. Additional thoughts, the test itself was cloud based. That leads me to think in the future we may see login type subscriptions for Creo and not even get disks to load on our computers. I do not think I would like that.
2. Flex modeling can have quick prototype value but I think it could have disastrous affects if the model is left "as prototyped" and taken into production.
3. The RMB menus ROCK! I am not a fan of the ribbon. Using Pro/E since the cascading menu days, I liked the Wildfire 4 system the best so far but moving menus to the RMB is a huge benefit over the ribbon.
4. The system colors are still modifiable. That means I will still be able to continue with the Pre-Wildfire customization.
