Mapkey: Finding path/steps followed by Mapkey
Nashnir
We have just upgraded from WF4.0 to Cre2.0 m090.
Due to this many mapkeys are not working and hence I was wondering is there is way to find out the path followed by existing mapkeys in WF4.0
If there is a way to find out the steps then we can manually re-create them in Creo2.0
I am asking this because there can be certain steps that could be missed if we try without knowing the steps and only the end result occuring in WF4.0
Thank you.
dschenken
(To:Nashnir)
You can open the file containing the mapkeys with a text editor and examine the contents.
Unfortunately the steps that are recorded may not make very much sense because they record user interface calls which are not always plain or obvious.
dschenken
(To:Nashnir)
I noticed that.
The mapkeys can be exported as config.pro from WF4.0 but the options ( path followed ) are shown by their variable name. ( I guess).
Is there a documentation which will help us map the respective names to the features at user end?
Dale_Rosema
(To:Nashnir)
Especially when you are using legacy mapkeys that you did not create, so you are not sure how to re-create.
Thanks, Dale
