WHY isn't it there?
WHERE do I send my hate mail?
WHAT are you going to do about it?
HOW about you add the 3 lines of code to fix this problem in the next version so companies don't have to spend millions to work around dumb artificial restrictions on customization?
WHEN is it going to happen?
WHO thinks PTC even reads these?
I'll hang-up and listen.
I agree, that the entire hole table should already be populated by PTC, out of the box, but...
Edit the hole table that is included with Creo to include the values you want.
I modify the OOTB hole files anyway because the PTC supplied tables use theoretical values and we use actual values for drill sizes.
Only has to be done once and moved to a new version with ease.
Unfortunately, there isn't even an OPTION to set up Medium Fit for clearance holes on inch based fasteners. Only for Metric. We've been using custom hole tables for many years.
