Model Tree display in the "Navigation Tabs"
gkemner
User does not have the option to display the Model Tree in the "Navigation Tabs".   How do I get that option back?
gkoch
(To:gkemner)
Hello Greg,
Usualy the model tree is displayed when a model is open.
Then you can switch to Layer Tree instead and back to Model tree from the Show > Model Tree.
Then one layer higher there are the tabs for Tree, Folder Browser and Favorites.
And finally in the lower left corner you can switch Navigator on/off.
Is any of the buttons inaccessible or did it disappear?
Gunter
SYNDAKIT
(To:gkemner)
I would check these two things.
1) in options>window settings> heading "model tree settings"
     is "display as separate window" checked or unchecked?
               (should be unchecked)
2) in the config.pro options     enable_tree_indep yes/no
          (should be no)
if both of these are set correctly and you are still not seeing the tree, go to view>show>model tree
