Modifying hidden line
mselamat
Hi, how to change hidden line colour for Pro Engineer Wildfire 5.0?
Hello, you need to click View, Display Settings, System Colors. You then select Hidden line & change the colour. If this is to be permanent you will need to save a new system colors file in your load point directory & point your config.pro file at it.
John
John
you can change your color scheme according to your needs.
View > Display Settings > System Colors > Graphics tab > Hidden Line item
MH
Martin Hanák
Hi John & Martin,
Thank you. It simply works!
Muzzammil
