Hello community,
I have a set of notes and i want to use these notes whenever i need.
how to link a note with note parameter.
kindly find the same.
Bharath
The parameter is linked to the note by it's ID number, it doesn't show the contents of the note in the parameters dialog. When you use the parameter in another note it displays the notes contents.
