Photorender and Photolux lighting issues
swschultz
Rendering Gurus,
I have been beating my head against the wall attempting to get rid of a
vertical shadow line in an image that I am rendering using Photolux
rendering engine. I have tried moving lights, adding lights, removing
lights, but it seems that no matter what I do, the shadow line remains. The
only thing I can definitively say is that if I rotate the model a little bit
prior to rendering, the shadow line moves a bit to the left or right in the
rendered image. Has anyone out there come across this and have a solution
for me? It may be difficult to see in the attached image(which I hope shows
up in this message), but hopefully you can understand what I am talking
about regarding the shadow line. All input is greatly appreciated!
Scott W. Schultz
3D Relief Inc.
0 REPLIES 0
