Style environment glitch in WF3 F000
ptc-40436
I created 3d curves in style environment using intersected sections as references then created some surfaces. When I leave the environment everything is fine and looks good, but , when I return to the style to edit it the curves I ahve created become twisted and make some strange attachments. I did not edit any of the references. anyone have this issue?
I found my own solution, apparently, hiding the references seems to cause this problem...
