Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I am trying to convert a autocad "dwg" file to pro. The web stie that has these files is posting them in 2d and 3d. They also are posting up "microstation" Thes files are on the "victaulic" web site.
