enabling model tree seperate dialog box
mrd
can anyone let me how to enable the model tree seperate dialog box creo 2.0 ,earlier i use to get this ,now it is disabled.
it  willbe in view-->show-->model tree
7 REPLIES 7
rubenvillarreal
(To:mrd)
There is a way, but it will close as soon as you make a new feature. Right click the part and click View Changes, and undock Model Tree appears.
mrd
(To:rubenvillarreal)
thanks for your reply but i m more concern about how to activate the view-->show-->model tree
rubenvillarreal
(To:mrd)
I misunderstood your question, use this button then.
StephenW
23-Emerald II
(To:mrd)
maybe Model Tree Won't go back into browser
Silver
it's very confusing. hopefully I recall this correctly, add these 2 configs..
www_tree_location=out
enable_tree_indep =yes
restart Creo and goto windows settings and then you can set which side, etc
I'm not sure why I couldn't get it back in, I've done it from time to time if I need a lot of columns. i wouldn't recommend it.
i would recommend floating the layer tree with.......
floating_layer_tree=yes
i've never had a problem reverting that, it requires a restart too.
mrd
(To:mrd)
hi
i have added  floating_layer_tree=yes in my config.pro,but still it's not working out
StephenW
23-Emerald II
(To:mrd)
Set these 3 options in the config.pro
www_tree_location out
enable_tree_indep yes
floating_layer_tree yes
save your config.pro
in the file options windows settings, click the box DISPLAY AS SEPARATE WINDOW
make sure you save those settings also
close and restart creo
SteveFowler
(To:mrd)
I have a treetool txt file in my start in directory that seems to affect my modeltree window on my secondary display. I thought I created notes on how to set this up but I can't find them today.
