idx
IgorPerez-Uria
idx
Any ideas about generating IDX files from Element direct?
No, because I do not know what .idx has to do  with a 3d cad
Google:
The file extension .idx usually denotes an index. Such is created by various programs and uses. Do you want to open an IDX file, you must use for each matching application.
Most references an IDX file to a database, because the index is intended to speed up the search in a database. You can open a file IDX usually only when you access the program that the IDX file created.
Which program should open your .idx file?
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
FriedhelmK,
You haven't needed to import PCB's (Printed Circuit Boards) have you?
IDF, IDX
Mike
IDX Info exchange is possible from CADENCE/ALLEGRO to PTC  CREO PARAMETRICS/SOLIDWORKS that I know
IDF info exchange is possible from CADENCE/ALLEGRO to PTC CREO PARAMETRICS/CREO ELEMENTS DIRECT that I'v tested
Take a look at this discussion ECAD-MCAD collaboration
Marco
This is a thesis on ECAD-MCAD collaboration https://www.theseus.fi/bitstream/handle/10024/72206/Valkky_Markus.pdf?sequence=1
It talks also about IDX format
Marco
