so good !!
syang-3
so good !!
so good !!
can i have the PRT file.
Hi
You should reply to specific post/discussion
Because your discussion does not specify which part file you need
K.Mahanta
Hi
K.Mahanta
u open new file and then click on prt file window automatic open for u make any feature are
model by using sketch tool and and editing tool
ok bye
VladimirN
24-Ruby II
(To:syang-3)
What do you mean?
