Creo Flow Analysis Tips and Techniques
No ratings
Check out this video on Creo Flow Analysis Tips and Techniques session  from PTC Application Engineers.
Presenters: Lino Tozzi (Solution Consulting, Fellow) and Ryan Butcher (Solution Consulting, Fellow).
Creo Flow Analysis Learning
(view in My Videos)
Comments
WEBCAST Q&A
Question from Daniel:  Can autoscaling be turned off?
Answer:  Yes, the option is - sketcher_auto_scale_dimensions "yes/no".
WEBCAST Q&A
Question from Dominick:  Can you remove just the pattern without removing the "base" feature in Creo 9?
Answer:  Use "Delete Pattern" and it does just that.
WEBCAST Q&A
Question from Trevor:  Can you split a surface using only a line, or does it need to be an enclosed shape?
Answer:  Just a line will work as long as it reaches the current surface boundary.
WEBCAST Q&A
Question from Zachary:  If you split the surface, can you apply different properties?
Answer:  Yes.  Try various properties that you might need.
‎Nov 29, 2022 01:30 PM
Labels (3)
Contributors
