Creo "Sketcher" Tips & Techniques Session Recording (West Coast)
100% helpful (1/1)
Check out this video on Creo "Sketcher" from PTC Application Engineers
Presenters: Emily Pinto (Solution Consultant) and Ryan Butcher (Solution Consultant, Fellow)
Original Date Presented: March 19, 2024
To dive deeper into the subject, check out Creo "Sketcher".
Comments
I believe the dimension on the end point of a spline actually controls the radius at the end of the spline.
From Creo 7 help:
WEBCAST Q&A
Question from Leannah:  Can you save a custom shape permanently into the palette?
Answer:  If you want to make your custom sketch permanently available even after restarting Creo, follow this step:  a. Save your custom sketch to the folder; b. Copy the folder containing your custom sketch to the Creo installation directory (...\Creo<version>\Common Files\F000\text\sketcher_palette/
WEBCAST Q&A
Question from Michael:  There used to be a cheat sheet showing keyboard shortcuts.  Is there anything like that today?
Answer:  Here you go:  https://support.ptc.com/images/cs/articles/2022/12/1671049417Go6T/219841_Quick_Reference_Card_for_Creo_9.0.2_11_11.pdf
Creo 10 version:  https://www.ptc.com/support/-/media/support/refdocs/Creo_Parametric/10,-d-,0/quick_reference_card_for_creo_10.pdf?sc_lang=en&source=search
WEBCAST Q&A
Question from Scott:  Us the auto scaling of dimensions of the sketch new to Creo 9?  I have not seen that happen on any of my sketches (we are currently on 8).
Answer:  Yes, it was introduced in Creo 9.
‎Mar 27, 2024 03:46 PM
Labels (2)
Contributors
