A great video, very clear and helpful!🏆🖕
Because it is not convenient to listen to the sound in the office, adding notes is a good alternative😀👍👍👍
These are a great start for each company to create their own start templates. We just recreate our start file templates from the PTC OOTB Creo Parametric 5050 ones before moving Creo Parametric 5050 into production. It is a good idea to do about every 5-6 years because even though you save them in the new release, sometimes the new functionality is not built into them.
