Automating Drawing Sheet Creation
Ramsin_93
Does anyone have any tips on establishing a drawing template configured to automatically create drawing sheets based on the assembly and part names? I have an assembly structure on Windchill that i want replicated in the form of individual drawing sheets in one drawing, and preferably have the corresponding active model set and maybe a top view in the center.
I am unfamiliar with any methods besides mapkeys (which I have not been able to achieve my goal with), my main software of expertise is NX, which mainly utilizes Excel sheets and even a VBA macro recorder for automating tasks.
Any ideas or help with my challenge would be greatly appreciated, thank you.
sully7
(To:Ramsin_93)
This is definitely possible with Pro/TOOLKIT (or Object Toolkit). Mapkeys would "help" get you to a half-way solution... but to get the "click-of-a-button" type solution that you are looking for, you would definitely need some customization.
There are a lot of options when it comes to APIs in Creo. These are essentially different languages that enable you to build customization. There are "free" APIs for VB, Javascript (although, I definitely don't recommend that one)... but those have very limited functionality. There are also "paid" APIs, which essentially enable you to automate the power of anything you can do "manually" -  Pro/TOOLKIT is based in C, and Object Toolkit (OTK) is based in either C++ or Java.
Do you know if you currently have access to licenses for either? Either way, - CadActive has a lot of expertise working with automation such as this and would be able to help you define/develop a solution such as this.
James Sullivan
President & Founder
CadActive Technologies - www.cadactive.com
Ramsin_93
(To:sully7)
Thank you.
TomU
(To:Ramsin_93)
As mentioned, you are going to have to create (or buy) some customization.  This can definitely be done with SmartAssembly.  It looks like you could also do this fairly easily with Nitro-CELL.
