Basic question about ProSurfaceDataGet
K_V
Hey guys,
I got a question about outputs I got from ProSurfaceDataGet.
I  have uv_max & uv_min from surface data, which are values referring to UV coordinate, I know UV is a surface created to cover the whole surface, but I don't know if it is a plane or quilt, if it is a rectangle or in other shape.
I need to write essay, and this is part of it, thus I have to fathom it clearly and precisely.
Do you guys have any ideas about this ?
I put what I perceived below, I don't know whether it is right, pls correct me if I'm wrong.
BIG THANKS !
Ketan_Lalcheta
(To:K_V)
Hi
ProSurfaceDataGet is the API which gives you structure ProGeomitemdata as output.
ProGeomitemdata* p_data_ptr;
p_data_ptr->data.p_surface_data->srf_shape;
p_data_ptr->data.p_surface_data->type;
Above two information from geomitemdata structure might be helpful to you.
HIH
Ketan
RPN
18-Opal
18-Opal
(To:K_V)
*p_surf_type will tell you the Type, contour parsing may your next job 🙂
extern ProError ProSurfacedataGet ( ProSurfacedata *p_surf_data,
    ProSrftype *p_surf_type,
    ProUvParam surf_uv_min,
    ProUvParam surf_uv_max,
    ProSurfaceOrient *p_surf_orient,
    ProSurfaceshapedata *p_surf_shape,
    int *p_surf_id );
typedef enum pro_srf_type
    PRO_SRF_NONE =     -3,
    PRO_SRF_PLANE =    34,
    PRO_SRF_CYL =      36,
    PRO_SRF_CONE =     37,
    PRO_SRF_TORUS =    38,
    PRO_SRF_COONS =    39,
    PRO_SRF_SPL =      40,
    PRO_SRF_FIL =      41,
    PRO_SRF_RUL =      42,
    PRO_SRF_REV =      43,
    PRO_SRF_TABCYL =   44,
    PRO_SRF_B_SPL =    45,
    PRO_SRF_FOREIGN =  46,
    PRO_SRF_CYL_SPL =  48,
    PRO_SRF_SPL2DER =  50
} ProSrftype;
