Can we lock/unlock a model in workspace using ProToolkit API?
skadam-5
2-Guest
In Creo integrated with Windchill, the top level assembly only is checked-out , and bottom parts are in check-in status.
Can we put a lock to the bottom parts to prevent them from modification using ProToolkit API?
In interactive mode it is supported (PFA).
You can't prevent it. But you can check it inside your toolkit program before you change it from this side.
  pfcSession_ptr session = pfcGetProESession();
  pfcServer_ptr server = NULL;
  server = session->GetActiveServer();
  checkedout = server->IsObjectCheckedOut(server->GetActiveWorkspace(), mdl->GetFileName());
Br,
Eike
As far as I know you can only check the status.
Function ProServerObjectIsModified
Description
Checks if the given object is modified in workspace/locally.
Synopsis
#include <ProWTUtils.h>
ProErrorProServerObjectIsModified(
wchar_t* server
/* (In)
The server alias.
wchar_t* workspace
/* (In)
The workspace name.
wchar_t* object_name
/* (In)
The object name
ProBoolean* checkout_status
/* (Out)
PRO_B_TRUE if the object is currently checked out.
ProBoolean* modifiedLocally
/* (Out)
PRO_B_TRUE if the object is checked out and modified.
ProBoolean* modifiedInWS
/* (Out)
PRO_B_TRUE if the object got modified in Workspace.
Returns
PRO_TK_NO_ERRORThe function succeeded.
PRO_TK_BAD_INPUTSOne or more arguments was invalid.
PRO_TK_E_NOT_FOUNDThe given object is not in the workspace.
PRO_TK_BAD_CONTEXTThe server was not registered or the workspace couldn't be found on the server.
