Hi Folks,
Where I can find Creo Object toolkit configuration and Demo video in PTC support portals? please help me out. I have installed Visual studio as per GSG guide found from common files\otkcpp folder but its not working as expected.
Santhosh
"[Knowledge Hub] Creo Parametric - Object TOOLKIT C++": https://www.ptc.com/en/support/article/CS318243
