I'm new to creating customizations in Pro/ENGINEER and could use some help. I have a J-Link program that creates a PDF of a drawing after making some changes to each sheet prior to printing. After the drawing is printed, I am removing the changes that were made and I would like to set the drawing modified status back to what it was prior to running the program. I've done something similar to this in Office applications that I have created and I hope I can do something like it in Pro/ENGINEER.
Mark Bohannon
