Hello
I have created a revolve using Creo toolkit.
Code is working fine without setting model accuracy or epsilon value through toolkit for few part.
On bigger diameter test part, revolve sketch was shown incomplete. This got resolved by setting epsilon as 10 power -9 and relative accuracy of 10 power -4 through code. Again for few parts, sketch is not allowing to create revolve.
Any idea on this issue? Through toolkit, I am adding minimum of length of line as 0.012 but epsilon is already too small. Why it's failing?
Any thoughts will be of great help.
Thanks in advance...
Ketan
