Extract Termination (Wire Table) for Creo Harness Manufacturing HMX with Java
RLEECI
6-Contributor
Our company is very new to PTC Creo and we are investigating into some automation/customization
(1) Is it possible to extract termination table (also wire list) to Excel with Terminal, Seal, and Plug P/N with Java?
If yes, please point me to some suggestion
(2) Will it require more than free Jlink license?
RLEECI
6-Contributor
(To:BillF)
Thank you very much for the info.
The report will be from Creo Parametric. We have not started to write any report yet as we are confirming if it is even possible to have JLINK (or OKT) pulled HMX data within Creo Parametric environment.
We are investigating about feasibility and if we need to purchase OKT license.  Hopefully, there some firm/some one has done this.
BillF
(To:RLEECI)
Have you written reports for the data you want within Creo Schematics or Creo Parametric?  If so, you can open the report and save it as a CSV file.
If you are using HMX, the best source for information is Brian at Virtual Interconnect.  http://www.virtual-interconnect.co.uk/
They created HMX
RLEECI
6-Contributor
(To:BillF)
