Getting error while creating offset section" Feature aborted:Cannot recreate internal datum"
AI_10095062
6-Contributor
I am trying to create offset section but after creating section the feature is getting failed and failure info shows"Feature: Failed regeneration.
Feature geometry can not be restored.
Reasone for failure-
Feature aborted: Cannot recreate internal datum."
Please help if Anyone have solutions to this problem.
1. What version of Creo are you using?
2. A similar issue earlier - "Assembly aborted because of missing datum": https://community.ptc.com/t5/3D-Part-Assembly-Design/Assembly-aborted-because-of-missing-datum/td-p/44424
And also the article - "Interchanging of component with Creo Parametric 4.0 Toolkit function ProAssemblyAutointerchange() causes regeneration error despite setting of config.pro remember_replaced_components =yes": https://www.ptc.com/en/support/article/CS276989
AI_10095062
6-Contributor
(To:VladimirN)
I am using Creo4.0
