How to Undo the operations created by Object toolkit
RS_9601780
I am creating some features using Object toolkit application C++.
But once operations are done, I cant undo them.
Is there anyway with which I can add undo point till the state before I started by application
  1. erase modified model from session
  2. open the model from disk
Martin Hanák
Hello Martin,
Thank you for your reply.
Your suggestion seems great, but it may not fit my requirement.
As there are multiple operations are done on part, I just want to remove last operation that was done on my part. Just last.
I see a way around with using your suggestion, but Can you please help me with Object Toolkit code/function for the erasing and reopening model.
@RS_9601780 wrote:
Hello Martin,
I am sorry i can't help you I am not software developer.
Martin Hanák
Hi Martin,
Thank you for your kind reply. I will search for the probable solution and update if I find one.
Thanks again
