How to add "Text Symbol" to dimension by TOOLKIT?
XJ_10040599
I am using Creo Parametric - Release 4.0 (connected) Release 4.0 and DatecodeM150
请问如何使用TOOLKIT给尺寸文本添加“文本符号”?
How to add "text symbol" to dimension text using TOOLKIT?
Translated with google translate by Iuliana Nuta, 16. june 2022
remy
(To:XJ_10040599)
Hi your application needs to perform the following:
that's to say Select an existing dimension then browse Dimension tab > and pick a symbol in the palette.
Once your application gets the dimension, here is the function to call to set a Symbol: ProDimensionSymbolSet()
The page points to the shipped example: TestDimension.c:
remy
(To:XJ_10040599)
