Hi for all!
I need to create offset planes using the j-link.
Does anyone know how to do it?
Thanks!
I don't think that this is possible with J-Link, but you can do it with TK / OTK this way (Just create it on std. system, but you can create it on other positions too) : --> (sry for no comments)
So if it's possible in J-Link it should work the same way, but with Java API wrapper.
void createADatumPane(int c_sys_pane_type, wchar_t * panename, ProFeature * feat) {
ProElement pro_e_feature_tree, pro_e_feature_type, elem_const_type, elem_offset, pro_e_std_feature_name, elem_consts;
ProErrorlist errs;
ProError tkerr;
ProValueData value_data;
ProValue value;
ProFeatureCreateOptions opts[1];
ProName wide_string = L"";
ProModelitem p_mdl_itm;
ProSelection sel;
wcscpy_s(wide_string, PRO_NAME_SIZE, panename);
ProElementAlloc(PRO_E_FEATURE_TREE, &pro_e_feature_tree);
ProElementAlloc(PRO_E_FEATURE_TYPE, &pro_e_feature_type);
value_data.type = PRO_VALUE_TYPE_INT;
value_data.v.i = PRO_FEAT_DATUM;
ProValueAlloc(&value);
ProValueDataSet ( value, &value_data );
ProElementValueSet ( pro_e_feature_type, value );
ProElemtreeElementAdd ( pro_e_feature_tree, NULL, pro_e_feature_type );
ProElementAlloc ( PRO_E_STD_FEATURE_NAME, &pro_e_std_feature_name );
value_data.type = PRO_VALUE_TYPE_WSTRING;
value_data.v.w = wide_string;
ProValueAlloc ( &value );
ProElementValueSet ( pro_e_std_feature_name, value );
ProElemtreeElementAdd ( pro_e_feature_tree, NULL, pro_e_std_feature_name );
ProElementAlloc (PRO_E_DTMPLN_CONSTRAINTS, &elem_consts);
ProElemtreeElementAdd (pro_e_feature_tree, NULL, elem_consts);
ProElementAlloc (PRO_E_DTMPLN_CONSTRAINT, &elem_offset);
ProElemtreeElementAdd (elem_consts, NULL, elem_offset);
ProElementAlloc (PRO_E_DTMPLN_CONSTR_TYPE, &elem_const_type);
value_data.v.i = c_sys_pane_type;
ProValueAlloc (&value);
ProValueDataSet (value, &value_data);
ProElementValueSet (elem_const_type, value);
ProElemtreeElementAdd (elem_offset, NULL, elem_const_type);
opts[0] = PRO_FEAT_CR_DEFINE_MISS_ELEMS;
ProMdlToModelitem(addFirstKEsFeatureVisitModel, &p_mdl_itm);
ProSelectionAlloc(NULL, &p_mdl_itm, &sel);
tkerr = ProFeatureCreate(sel, pro_e_feature_tree, opts, 1, feat, &errs);
if (tkerr != PRO_TK_NO_ERROR) {
writeRunnerLog(L"Can't create the datum pane.", 2);
} else {
setCost(1);
ProSelectionFree(&sel);
ProElementFree(&pro_e_feature_tree);
createADatumPane(PRO_DTMPLN_DEF_Y, L"YayImNew_Y", &feat);
Best regards,
Eike
PS: Please close the question if this answer reaches your needs. So the topics overview get better. Thx
Thank Eike for the return, but the problem is that I don't have the TK / OTK, only J-Link.
There is an example in J-Link API that I'm unable to do, as the following image.
Thanks!
I had a quite similar problem creating coordinate systems and datum planes with web-Link.
The best way to solve that, was to use UDFs.
Take a look here.
