How to create a mapkey that toggles a custom layer
pmuewi
I've found instructions to toggle a custom layer that include writing two .pro configs, then referencing those in the mapkey, but those instructions are from around 2012, and I'm wondering if there is a more straightforward way to toggle a custom layer with a single mapkey.
I've currently got a mapkey that hides a custom layer, "CURVES", with the following code:
mapkey z ~ Select `main_dlg_cur` `PHTLeft.PHLayerUI.AssyTree` 1 \
mapkey(continued) `node0:CURVES`;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.PHLayerUI.AssyTree` `node0:CURVES`;\
mapkey(continued) ~ Command `ProCmdViewHide` ;\
mapkey(continued) ~ PopupOver `main_dlg_cur` `LayerActionMenu` 1 `PHTLeft.PHLayerUI.AssyTree`;
Is it possible to modify this to allow for toggling?
Currently using Creo 11.0.4.0
(To:pmuewi)
Short answer is no. In order to "toggle" using mapkeys you will need to create two versions of the mapkey and call them on the fly within Creo using config.pro files or mapkey.pro files if in Creo 11+.
Refer to the video demonstration and sample code posted in this previous thread which will explain what needs to be done to get a pseudo toggle to work. It is not a true logical toggle as the current state is never known but in practice this will not matter.
Solved: Mapkey Toggle Grid (HIDE Grid / SHOW Grid) - PTC Community
You will need two versions of the mapkey saved with the same mnemonic to two files to be read in on the fly. One version will show your layer, and the other version will hide your layer. Each of these mapkeys must include code that redefines what the mapkey does (show/hide). Below are the mapkeys used to enable the glow function shown in the video. The toggle action is completed by changing the setting of config option "enable_selection_glow".
!**** Toggle function for selection glow
enable_selection_glow	no
!**** mapping mapkey to turn on glow
mapkey $F4 @MAPKEY_LABELGlow Toggle;%.ifcp;\
mapkey(continued) ~ Input `file_open` `Inputname` `D:\\ProE Standards\\Config Calls\\on_glow.pro`;\
mapkey(continued) ~ Command `ProFileSelPushOpen_Standard@context_dlg_open_cmd` ;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;
enable_selection_glow	yes
!**** mapping mapkey to turn off glow
mapkey(continued) ~ Input `file_open` `Inputname` `D:\\ProE Standards\\Config Calls\\no_glow.pro`;\
(To:pmuewi)
Hi @pmuewi,
Anurag
