This short guide explains how to create electrodes with surfaces in SMARTElectrode:
# | Description | Selection | Result |
1. |
"Add" new electrode Select burn-faces and press Strg+c and Strg+v or press "CopyGeometry". |
2. |
Activate filter for boundary edges Select start and end of chain Convert to "Edge-Chain" in context menu Use "Extend in Direction" from context menu and choose direction |
3. |
Select curve chain Use "Extend" from context menu Choose method tangent and set distance to extend Apply changes |
4. |
5. |
Activate filter for quilts and select quilt Use "Attach" to connect with FREE_FACE and to create a solid "Attach and add support" is also accessible for quilts
6. | Use "Mirror" and select surface to mirror solid | ||
7. |
Add "Base" |
