I want to generate a square Image of 1000x1000 pixel from Creo Rendering.
Currently the images generated are in Rectangular format (500x1000).
Also is there a way to change drawing window size width through config file ?
Thanks in Advance…..
I need it in 1000 X 1000 resolution
if you are PTC Customer with active support then contact PTC Support directly and ask them the same question.
https://www.ptc.com/en/support/article/CS414760
Hello @ps5,
It looks like you have some responses for your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
