How to read point bend location from Pro-piping in ProToolkit ?
ppandarkar-2
Hi..
I have a pipe assembly created in pro-piping, now i want to read its bend location from ProToolkit, so please can i know its API or any other way to read it.
From front end i can get it from Piping -> piping info -> bend location -> select pipe segment -> select csys.
Thanks.
Prashant Pandarkar
Hi Prashant,
I have not ever programmed this activity but here are 2 possibilities off the top of my head.  BTW, I am using the WF 5.0 Pro/TOOLKIT API.
  1. Use the Pro/DEVELOP function prodb_get_pipe_feat_refs and interrogate the returned Select3D object.  The Select3D object can be accessed with the ProSelect* functions.  This might get you what you are looking for.
  2. If #1 doesn't work then you may have to extract information from the feature element tree by using ProFeatureElemtreeExtract and then using the ProElem* functions to retrieve the proper data.  I'm not sure if Piping features are supported in Pro/TOOLKIT with the element tree but it's worth a try.
Hope It Helps,
Patrick Williams
I just went through this while trying to convert an application from Pro/DEVELOP to Creo Parametric 2.0 Toolkit which used a pipe feature.
prodb_get_pipe_feat_refs has no equivalent in Toolkit. The pipe feature element tree is not exposed. The pipe feature is obsolete in CP3.
