Issues Editing Check and Constant Files in Creo ModelCHECK Configuration
s_kaandemir
I'm using Creo 12.4.0.0 and I'm experiencing an issue when trying to edit certain configuration files in Creo ModelCHECK. Here is the situation:
I can edit Start Files and Status Files under the Configuration Files section without any problem.
However, when I try to edit files under Check Files or Constant Files, Creo crashes.
For example, I tried openin the default_checks_mch, file but Creo immediately crashes.
The crash only happens when editing Check/Constant files, not Start/Status files.
Hi @SD_13694836,
Thank you for your question.
Anurag
