Hey, I have a few mapkeys where I use the pause with the resume prompt/popup. (I've included a picture for clarity)
There is no need to hit cancel but if you do click cancel instead of "Resume" it leaves you in an undesired state.
The preferred fix would be to remove the "cancel" button entirely and only show "Resume".
Is this possible and if so, how.
I've tried modifying lines in the config file with no luck so far.
Thanks!
Personally, I use the cancel button occasionally to stop to mapkey at a pause. STOP might be a better name for the button as it does not undo what has already been done..
Hello @MORECREO,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
