Hi, I've been working through the dark maze of the VBA API, and the documentation for running routines using the Excel VBA is as remarkably sparse. I am having difficulty trying to determine how to handle a CpfcPoint3D object in an Excel routine. I have VB examples; but, I'm unable to determine how to structure the same in Excel. Here is what I have in the Excel routine;
Dim location As CpfcPoint3D
Set location = New CpfcPoint3D
location.Set(0, 10.0)
location.Set(1, 10.0)
location.Set(2,0)
(Excel objects to the .Set method for a location array. But, this is the example for a VB routine)
This is an example from a VB routine (from the PTC VB API documentation);
Dim pointLoc As IpfcPoint3D
pointLoc = New CpfcPoint3D
pointLoc.Set(0, 200.0)
pointLoc.Set(1, 600.0)
pointLoc.Set(2, 0.0)
Is there any VB API guru that can tell me what I'm doing wrong with my own code?
Thx!
