Hi I am new to object Toolkit Customization..
I have create one project using object Toolkit and compile
successfully.
But When I integrate with Creo it is provided error “PRO_TK_General_Error”
Please Guide or provide solution.
Hi
I didn't have the time to check your project, but I have a working project frame here : https://modelprocessor.inneo.com/updates/VS2010Proj.zip
You just need to change some of the path's so it should build with tk and otk support. Just ignore the warnings we have solved that in another project I need to look there while that happens but it should work.
Br,
Eike
Hi
Br,
Eike
Thanks Eike..
It is working fine.
