Not able to retrieved all the displayed ordinate dimensions(start from "oad") of a drawing view through Creo Parametric Toolkit API.
ndaslaniya
I want retrieved all the dimension....here I have attach code and dummy drawing for the same. Please provide any approach or work around to retrieve ordinate dimension.
have you tried ProSolidDimensionVisit and ProDrawingDimensionVisit?
Thanks Gabriel....but not work...
Yes..I have tried both API...It is provide dimension which is start from "ad" and "od"...
It is not retrieve all dimension from drawing.
I already attached code and sample drawing file.Please validate at your end and let me know the solution or work around....
