PCF files and printing to a network printer
MGortner
I have 2 printers for different sized papers and I'm trying to use a PCF
file to send a document straight to one of the printers. As I watch the
printer status (it's networked), the document spools but never prints.
Any ideas why?
An example .pcf:
plotter POSTSCRIPT
button_name Test
button_help Plot a A-size
plot_drawing_format YES default
plot_segmented NO default
plot_roll_media NO default
plot_label NO default
plot_handshake software default
create_separate_files NO default
plot_with_panzoom NO default
rotate_plotting NO default
allow_file_naming YES
plot_name YES
interface_quality 3
plot_destination printer default
plotter_command windows_print_manager \\computer\printer
plot_file_dir C:\users\
pen_table_file Z:\...\thin_print.pnt
plot_sheets current default
paper_size A
paper_outline NO default
plot_clip NO default
plot_area NO default
Matt
Design Engineer
Matt,
I've attached a .pcf file that sends the plot directly to a networked plotter or printer. You'll need to change the plotter address, plot size, and offsets to suite your situation. I actually created 3 separate mapkeys (C size, D size, & E size) based on variations of this .pcf to allow quick printing of the current sheet. You'll see that in the .pcf as well. Good luck!
Rich
Is there a config setting that will add a printer type to the pull down
list
so I don't have to scroll for it every time I create a plot file?
Terry Johnson
Senior Technical Specialist
Raytheon -- North Texas
972-344-5689
Save the earth. It's the only planet with chocolate by Craig Puetz
North Texas PTC/User Group -- President
Terry,
Why use the pull down menu? That's the reason I created mapkeys to print the various sizes. The mapkeys could be used to print the whole drawing although I've got ours to print the current sheet. Just depends on your work flow.
Rich
All I needed to do was make all my selections and save the .PCF file and
that did the trick..
some suggested mapkeys
some suggested that I needed to add button_name to the pcf file, but It
worked without me adding this..
Why is it always the simplest answer is the one you don't think of?
Thanks everyone.
Terry Johnson
972-344-5689
"Terry A Johnson" <->
08/02/2007 05:50 PM
Please respond to
To
cc
Subject
[proecad] - Printer Type
list
Terry Johnson
972-344-5689
